Old 03-08-2004, 05:07 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Do some tests. Connect a fuel pressure gauge to the car and drive it with it connected. If the pump is running, you should be getting about 3 to 5 pounds for a carb and as much as 39 PSI for EFI.
If the car stalls and you have pressure, it is most likely Ignition.
Personally, I know guys who have a points distributor in their trunk just in case.
Just a thought.
