Old 03-08-2004, 08:59 AM
Goober Goober is offline
Cobra Make, Engine: Superformance #1374 with 392 RDI Stroker
Same thing happened to me. The coil is mounted on the passenger side on the inner wheelwell. The coil wire was arcing next to the frame. I noticed it one night when the lights were off in my garage. Easy fix. If your wire is like mine, it didn't have much stretch to the distributor and was trying to pull away from the coil causing the spark to leak from under the rubber boot.
Try it and see.
