Old 03-11-2004, 01:45 PM
pneall's Avatar
pneall pneall is offline
Leeroy,
I mounted my battery , Optima gel type, in centre under the seat belt support frame. I cut opening in floor, made up box and dropped battery in about 100 mm. Then made up cover that holds it all in place. saves alot of boot space and looks neat,plus puts weight (16kg for battery) right over diff. I will send you email picture if you like. What address should I use.
It was good to talk to you at the GP. Had a good time at Mikes place checking out his Cobra.
Regards,
Phil
