Dave R
Although you have a valid point there is no need for concern. The amount of material removed is not great enough to cause a vibrational problem.Simply put the the hole which is located on a diameter of of say less than 3.00 inches spun at 150 mph has not enough mass at that diameter to cause the wheel to vibrate.However take that same amount of weight and remove from the tire area and you will have a significant problem. I have a Ford 9 inch in my cobra and there is no noticeable vibration at 150 at the track.
