Old 03-11-2004, 06:37 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Default Tilton reservoir bowls?
I have a Tilton(Wilwood ) tri master cylinder setup for clutch and brake. Just finished putting a new clutch and trans in my car, as we're bleeding the hydraulic clutch cylinder we discovered a leak from the clutch reservoir--the plastic reservoir bowl has a crack in it and will slowy bleed out everytime the clutch pedal is depressed.
I've contacted most every automotive and speed/performance shop in the Seattle/Bremerton area, as well as Jegs, Summit and Speedway. No one carries them as an aftermarket replacement Item. Only in the complete master cylinder kit. Thing is I've already rebuilt all 3 master cylinders and really don't want to spend 60-70$ on a new master cylinder, just for a 4 dollar piece of plastic. Even on the Tilton website they only show the rebuild or full kit. Tried a couple of others mfgs types but they won't interchange.
Anyone have any ideas? I'm at a loss right now
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
