Old 03-12-2004, 04:02 PM
barry barry is offline
Club Cobra Member
Cobra Make, Engine: Shell Valley KCR 393 Stroker Cleveland
I have the same battery, put a cut-off switch in trunk as to not run battery dead. Have had the battery for two years, no problem. You might try a 10 amp charge on an automatic charger overnight. Have you checked your ground cable to frame? A bad ground can cause a charging problem.
I have one just like that, Only Different !
