Thread: 392 problems
Old 03-13-2004, 02:40 AM
NMattison NMattison is offline
Cobra Make, Engine: Antique & Collectible 351 windsor bored and stroked tko tremec
hi i would also check your msd for the miss but the vibration, has this always vibrated? i was wondering are you using a manual trans? if so did u balance the engine i have the tremec with stock 5.0 flywheel and i had to have the wheel drilled. so as it would be balanced with the engine. if not drilled it will cause a vibration hope this might help for my .02
