Thread: 392 problems
Old 03-13-2004, 08:08 AM
vbdig vbdig is offline
Cobra Make, Engine: venom 427, 392 crate motor
The engine came with flywheel, I assume it was balanced, as the engine was test run at ford. I did remove flywheel to install the steel backing plate for the bellhousing, but it seems that the flywheel can only go on one way. Is this correct? a pilot bearing was included in this package.
