Old 03-13-2004, 10:01 AM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Arrow
If they still have 4 lug axles it probably is c-clip eliminators, and they usually use stock axles. I would caution that most c-clip eliminators aren't recommended for street use so you want to make sure which kind you have. DTS in Michigan makes 8.8 housings with 9" axle tubes, so you can run 9" style axles and have the sealing and thrust retention that is the standard fare in 8and 9" rears.
WDZ
