Old 03-14-2004, 04:30 AM
Dominik's Avatar
Dominik Dominik is offline
hi mick,
the drag race traction out of corners should also be related to the anti-squat under acceleration.
Paul V. Valkenb.. pg 21:
Anti-squat in the rear is doubly beneficial, in that the desired tire patch movement is rearward, which absorbs bumps. An excess, however, can cause wheel chatter under hard acceleration.
Yes, I listed the values upside down for the rear to test you.. ;-)
Sorry, I had the drawing inverted.
The roll center though is based on the correct values.
rock 'n roll,
dom
If I don't respond anymore, that's because I can't log in
