Old 03-16-2004, 04:08 PM
Trueoo7 Trueoo7 is offline
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
Rick
Thanks for the photos that really helps alot. Couple of questions...How far would you say the fans are from the radiator? 1"-2" ??? I'm not sure why you used the red gasket material. Was that to take up any slack inside the larger tube because it looks like you bolted the brackets to the cross bar which would have tightened them up anyway? Also what size fuse did you use to protect the circuit? The POR 15 that you used....did that come in a spray can and did you spray it on the motors too?
Question for anybody: Does a hoop bumper come with some sort of side brackets already on it, and then you have to adapt that to the overriders?
Thanks again
Trueoo7
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
