mick,
I never checked the views... J
The rest of the week I use to clear my brain by working on the engine.
The spinning assembly is finished, on comes the
oil-pan not.
Its a deeper sump, I had to extend the pick-up first. On goes the pan, off it comes again. It needs a drain plug...
These are minor headaches compared to the whole project.
The lowered sump now positions the
oil pan 3.54 (90 mm) above ground with the chassis featuring 5 (127 mm) ground clearance.
BTW, the crank centerline (FE) I positioned 12.6 (320 mm) above ground measured at the parting line main cap to block.
Thats quite low, especially for the bellhousing. Its almost touching the chassis rails with a 2 high transmmission mount.
I use solid mounts to keep things from moving and to add some torsional stiffness to the chassis.
I recommend to move the motor 1 up for more clearance, which of course is detrimental for the center of gravity whereever that is located!
I got values from 12.6 to 14.1 (360 mm) for crank centerline to ground on variuous Cobras with FE engines, measured at the pulley bolt.
That is why I recommended elsewhere in the forum to buy the Daytona body/chassis kit which was offered for USD 5000,00 intead of building your own. One may save USD 1000,00 by do-it-yourself IF nothing goes wrong and you have all the equipment!
I wish I had better equipment and more space...
hey muz,
that is a good one. I rush out now to compare to what I got!
womder what is new in cape town as the Shelby SASA plant...
Dominik
If we are here to help others, they are here to get our rusted brains
