  #30 (permalink)
Old 03-18-2004, 12:56 AM
boxhead's Avatar
boxhead boxhead is offline
No worries at all Mike
I started on my gearbox last night, My first question is I can see how you have milled the selector part that sits in the front and rear holes but when you welded the 2 pieces together did you sit the top part flat on the bottom or did you have to sit it higher to have the hole where the gearstick sits in at the correct height?
Also a question about your headers, who are you getting to weld them all together? if it is Defillipo's would they be able to make a second copied set from yours? if so how much?
Let me know how you go with the fuel tank as I might ask if you could supply a second one, just tell me a price.
Regarding my engine I now also have a GTS300 engine I can use all the heads, cam, injectors, intake and throttle body from.
Cruising in 5th
