Old 03-18-2004, 07:49 PM
a427sc a427sc is offline
Boys, check with your favorite test facility. As of Monday they have changed the requirements for composit vehicle testing. Ct is somewhat unique in that we use the inspection year as the year of the vehicle, not the parts origin. Basically, the specs have been loosened considerably (does it run on all eight?) and all you need to do is a 2 stage idle/tailpipe test.
As for the glitch in the software, it is just that, a small error in code that uses the wrong factor in some test calculations. Agbar found it, not the state, reported it and have taken a very aggressive approach to reimbursment to the affected people. Now Agbar isn't perfect, but all these political hacks blowing steam are just making noise in an election year. I was told the state gets almost $80,000 per car that passes the testing from the Feds. So you want to just drop the program? Well don't scream about your taxes if they do.
