03-19-2004, 01:55 PM
ME
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Re: Turkey Pan Installation Tips
Originally posted by REDSC400
How many gaskets would you use?
2 gaskets; one between the manifold and the pan and the other between the carb and the pan
Are the both the same gaskets? (four hole or 1 hole?)
both of mine were 1 hole
Is a sealer or adhesive used or not?
didn't use any on mine
What is the torque on the four Carb Bolts?
tight enough to get a good seal, but doesn't have to be super tight; Big help, I know. Maybe someone can give you exact specs
Any and all input on this process would be greatly appreciated.
Might want to rethink installing the turkey pan for everyday driving. I've decided to take mine off for everyday driving b/c I'm convinced that the tiny filter doesn't flow enough air and serioulsy richens the mixture. I'll still install the pan for shows, etc. , but I think I am going to buy a big 14" K&N filter.
[/b]
Replica is not a dirty word.
