Old 03-19-2004, 06:51 PM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
I second what John 550 said. I had to do quite a bit of trimming before I installed mine (but I run a Demon - the pan looked like it was intended for a Holley). Then once I installed it, I had to take it back off and open up the throttle rod hole a bit. It looked like it had enough clearance until I'd "get on it" a bit and the motor would torque over and cause the turkey pan to rub on the throttle rod. Obviously that's a condition you don't want.
Chris
