Old 03-20-2004, 03:03 PM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Arrow
It sounds pretty typical (the heat), and that's what helps generate some moisture, also an unheated area will also generate more. You may be over powering you separator. I run large ones every 6-8 feet and also line drains extending down every 15 feet or so. I also like to drain the moisture from the tank daily (at least every other day), if you don't do that, the filter couldn't keep up with it.
WDZ
