Old 03-22-2004, 05:16 PM
tfarhood tfarhood is offline
Cobra Make, Engine: Backdraft #101, 342 stroker
Wayne,
If there is no ID tag on the unit, you have to open it up and get the cluster gear ID numbers. The casting numbers are worthless. The cluster gear numbers would tell you the gear ratios, torque rating, and a few other things. This info along with imput shaft length and other physical measurements could narrow it down to the probable year of production. I just went through the same excercise with my T5.
Good luck.
tfarhood
