Old 03-23-2004, 06:16 AM
luke-44's Avatar
luke-44 luke-44 is offline
Originally posted by Jetlaag
How does one measure the moisture content in the concrete of a garage floor??
Would you tape down a piece of plastic on a section of the floor?
If so how do you measure the content of the moisture??
Just curious as I am ready to paint my garage floor and am looking for any ideas for a cool paint scheme on the walls of the garage.
Jetlaag
Jetlaag - you are right on the money. ASTM standard D4263 (commonly called the "mat test") outlines a moisture testing procedure that calls for taping an 18" x 18" piece of plastic onto the floor- sealed with duct tape all around. After 18 hours, look for presence of condensation under the plastic - if none is visible you are OK. It is basically a pass/fail test. Where it gets fuzzy is if there is no moisture present, but the concrete is darkened under the plastic.
To measure exact content, you need fairly sophisticated equipment for the average homeowner - I would suggest you try the "mat test" first. Here is a link to more exotic equipment if you wish....
http://www.constructionbook.com/xq/A...x/default2.htm
I am out of country until Sunday. If you email me, I can forward the ASTM standard to you upon my return.
Bruce
Enjoyment may be 9/10's anticipation, but that last 10% is oh so sweet....
