Old 03-23-2004, 08:26 AM
Johnnyquest's Avatar
Johnnyquest Johnnyquest is offline
Cobra Make, Engine: CSX4853, Roush 451FE
You picked the wrong carrier! I looked around and found many had the same problem. I went with Intercity, they have a special setup whereby the backend of the entire semi lowers flat to the ground then you drive on, it picks it up about two feet then drive into the back of the semi. I would change to the real deal. I used them! I WOULD NOT CHANGE YOUR SETUP ON YOUR CAR! CAll another carrier!
JQ
68 Hertz~09 KR~FFR Coupe~CSX4853
