Old 03-23-2004, 10:02 AM
Tom Wells's Avatar
Tom Wells Tom Wells is offline
Hi Alisha,
Please regard this long-distance diagnosis as worth what you paid for it
It sounds to me as if you went the opposite way from what you needed to go.
Smaller injectors may help your problem.
Larger injectors can cause the no-idle problem you describe. The computer and injectors can support only so short a time for the injector to be open. If the O2 sensor keeps telling the computer the engine is too rich at idle, the computer keeps trying to cut back the time the injector is open. The larger the injector, the bigger the shot of gas at any given timing. Eventually the computer practically has to shut them off
My 521 CI engine works fine with 36 pound injectors, producing 412 HP at the rear tires through a power-robbing C6 automatic trans, suggesting a lot more at the flywheel. The air/fuel ratio is fine from idle up to max rpm, suggesting the injectors are plenty large enough.
Unless you have a supercharger and are producing well over 500 HP, you most likely need smaller injectors, not larger; say 30 pounds.
Try going to a dyno facility if there's one nearby. You should be able to verify the engine is way too rich at idle.
Hope this helps,
Tom
