Old 03-25-2004, 03:23 AM
Cal Metal Cal Metal is offline
Original Shelby Owner
The floats only weigh 25.5 grams so it doesn't take much pressure to overcome their ability to close the needle and shut down the fuel stream. EFI pumps run a minimum of 35 psi, and some up to as much as 100 psi (Mercedes). A fuel return line, however, is always a good idea, even with a standard electric or mechanical pump.
I especially like Terry K's idea of the on/off switch that is independent of the ignition. I had that set up in an old Corvette years ago. Makes for a nice security device, as well.
