Thread: Dip Stick
Old 03-26-2004, 06:38 AM
Rick Bagley's Avatar
Rick Bagley Rick Bagley is offline
Cobra Make, Engine: Unique 427 S/C, Red w/White Sripes, 427 SO, 4 speed Top Loader
Use a belt sander, fine grit and remove the chrome for about 2 inches. Then if needed use a file for your full mark and add mark. Remember to calibrate the dip stick if your using a non-stock pan.
Example: Canton Pans are 8 qt. systems, that means 7 qt oil pan and 1 quart in the filter, not 8 quarts in the pan. The system is 8 quarts, kinda misleading.
Eliminator
