Old 03-27-2004, 07:41 AM
TonyMadrid's Avatar
TonyMadrid TonyMadrid is offline
Cobra Make, Engine: A&C 351W, C4
Default Brakes
If you run off of one MC you will have to use a proportioning valve to balance the pressure - front vs. rear.
Also, whether you use one or two MC's, it is important to get the optimum pedal ratio. The distance from the point where the push rod attaches to the pedal to the end of the pedal should be five times the distance from the pedal pivot point to where the pedal attaches to the pushrod. A 5:1 Ratio.
Tony
