Old 03-28-2004, 07:33 AM
Jim Downard Jim Downard is offline
Cobra Make, Engine: Classic Roadsters, 393 stroker, Tremec 3550, about 425 hp, MDA GT40 289
Hey Ron,
Jim Downard here. Did you choose to ues the Ford Duraspark because of the CR wiring harness. I was running the Duraspark II ignition and dumped it because of various problems. Screwy timing advance kept making my engine run hot. I would pick up a miss (sometimes) under a heavy load, but always on the right side. I found a loose ground in the distributor, and I also found that the Duraspark II required a specific coil. With those items remedied, I still had a hot running engine. I bought an MSD 6AL ignition, MSD pro billet distributor, and an MSD coil. Problem solved. Engine runs cool, never misses, and runs stronger than it ever did. It's a tough pill to swallow, but dump the Duraspark and go with a quality performance ignition. You'll never regred the change.
Good luck,
Jim
Man, it would've been helpful to know that cop was behind me a minute ago!
