Old 03-29-2004, 06:19 AM
Mike Simard Mike Simard is offline
Cobra Make, Engine: Porsche 928 S4
Aside from the usual differential mounting points that have come up with SPF's, some other things to look at are the motor mounts. If you have a broken motor mount you will notice it mostly in low gear when the torque on the drivetrain mounting points is at its greatest. My car had a similar clunk and the main culprit turned out to be the driveshaft to diff bolts were loose.
