  #40 (permalink)
Old 03-30-2004, 03:33 PM
Ant Ant is offline
Default Seized knock off
What happens when this problem occurs, does the threaded adapter get damaged and need replacing as well as the alloy knock off?
Also whats the most commonly used anti-seize compound? or I suppose as long as some is used, I see Loctite make a Silver Anti-seize and a Nickel Anti-seize!
I see by the design of your lug nut remover it will do the job, would it also be worth making it so a long bar can go onto it, and hitting the other side of remover, but that may not be necessary due to the center shaft?
A J. Newton
The 1960's rocked!
