Old 03-31-2004, 09:05 AM
Bill Wells Bill Wells is offline
Cobra Make, Engine: Superformance 156, ex Paxton 351, now a 392 Ford Racing Stroker
i installed a Custom Autosound SECRET AUDIO model radio in my SPF, with the main unit and speakers buried under the dash out of sight. only visible item is the small 1-1/2x5" face plate that will swing almost out of sight mounted on lower edge of dash. it could be attached for easy removal if wanted. the radio works by infra red wireless remote . i had to add a power amp in the trunk though to get added power. antennae is mounted on fender behind pass kick panel. no am reception ( no ground plane) but fm is fine. a cd can be hooked up if needed too. better but visible speakers/location would improve sound as well. it is not high quality sound, but it will do. i take many 3-5 hr one way trips in the car and it is nice to have something to listent to. yes, you can hear it over the exhaust in 5th gear when cruising except over 75 mph when wind noise takes over. the pipes are music too, but the radio is a nice addition. with the top up and side curtains in place the sound is fine in all ranges/gears ecxcept at wot. i have seen many radios installed in under dash ( and IN dash) locations. if you mount it under the dash, locate it back from the front edge of the dash so when the rain catches ya off guard the rain will not run down the dash and into the unit. i carry a plastic baggie under the seat to place over the read out unit when the rain hits and top is not up. bill.
