Old 03-31-2004, 02:57 PM
pneall's Avatar
pneall pneall is offline
Leeroy,
Not going for front bumper but using quicklifts on rear for effect only. not sure how to mount number plate though.
More photos after side pipes and pin drives fitted.
Working on air intake at moment
I am using Ians twin spring set up but have noticed that the small spring is fully bound in the rest position. This dosent seem right so I need to do some research there. I think the main work now will be with getting the suspension right.
I am really happy with the way the Mike Murphy shifter relocation system works. Shifter is in just the right position . I just need to learn where all the gears are. If you get the opportunity make sure you fit a reverse lockout as reverse is easy to find on the way to fifth.
Regards,
Phil
