Old 03-31-2004, 03:12 PM
Leeroy's Avatar
Leeroy Leeroy is offline
I did the same relocation of shifter as per Mikes guidance but did not use the shifter unit but machined my own using existing shifter & some. Works really at static so hope its good at 5,000rpm !!! Also fitted reverse solenoid to avoid those embarrassing moments off the lights. Did you come up with your own rear gearbox mount as both Mike and I had different (brilliant) ideas on how it should be done. Interested as to how your paint job was done. Did you fit off car parts, then strip and paint or paint in stages. I have been unsure which way to go to avoid damaging finished paint job. Its currentl at painters to get undercaoted and finish painted in engine bay, do you think its a good idea
Leeroy
