ok maybe i'm not being clear enough. if you could look under your car and see if there is anything holding the parking brake cable housing at or near your rear brakes / wheel hub? this part is needed in being able to apply tension to the parking brake cable when the parking brake is applied. thanks...............john
p.s. it does not matter what kind of calipers / brakes you are using all parking brakes use the same mechanics........it's like the hand brakes on a bicycle (probably going to regret saying that).
