Old 04-05-2004, 05:16 PM
VitaminC VitaminC is offline
Smile Carroll Shelby Signature Series Pistons
Carroll Shelby Enterprises now makes forged FE pistons in most any bore size, compression ratio, pin height, and pin bore. We stock finished and semi-finished pistons, so if you have a custom or unusual application, we can finish a set to your spec.
Unusual overbores, compression ratios, or rod/stroke combos are no problem. For example, we just did a set of 12.5:1's with deep valve reliefs for a customer with a .030"-over 427 Tunnel Port using big block Chevrolet rods +.400" length, and a stroker crank. Another customer has ordered a set of 10.5:1 pistons for a 390 bored .030"-over with a 4.125" crank, LeMans rods, and non-Shelby aluminum heads. These are just a couple examples of some of the esoteric combinations we've done so far.
These are not reboxed other-brand pistons. They are produced from our own forging die, made specifically for FE's.
We're going to put some photos up and do an official release of this new product, but in the meantime I thought I'd just spread the word a little.
Chris Weisberg
(310) 538-2914
