Old 04-06-2004, 05:09 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
It is not a requirement to use the OD. You can use the D position on the trans and it will drive fine. Shift into OD when you are out on the freeway and "moving along".
Ron is right, much more than 3.5 and you are not going to be able to start out without at least barking the tires.
