Old 04-07-2004, 06:12 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Trularin is correct about the drain not being excessive if she has a clock or anything else that is hot at all times. Battery could just be so low in capacity that it will not hold a charge unless running. The load test is the easiest way to check that. If the battery shows ok, then make sure the alternator is putting out a full charge when it is running.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
