Old 04-07-2004, 03:35 PM
DavidWard's Avatar
DavidWard DavidWard is offline
Cobra Make, Engine: FFR 1204 With Stack Injection
Send a message via ICQ to DavidWard
Originally posted by terry mason
David, Thanks for the help. your pictures are a big help. My biggest problem is the way the top fastens to the windshield frame it looks like there is a reciever of some type on the top of your frame,how does the top fasten to the frame at this point? Bruce, finish line only list 7 items under top and none of them are clips to fasten the top to the windshield frame.
The top of the windshield frame is slotted, with a wider slotted section in the middle. The front bows should have a rivet-like stud in them. The head of the rivet slips into the wider slot, then the bows are moved outward and the studs are trapped in the narrower slot. Then they clamp to the side bars on each side. If they still have slop in them, you can use weather-stripping between them and the top of the windshield. I know all this is confusing, but like someone suggested, take a look at ERA's site.
David
http://members3.clubphoto.com/david251117/guest-1.phtml
