Old 04-07-2004, 05:07 PM
mr0077 mr0077 is offline
Cobra Make, Engine: ERA 427 SO
Also, just to build on/clarify Cal Metal's diode thought, check to see if there is a change in amperage draw when you connect/disconnect the main power wire at the alternator (with the motor and key off)...if no diode problems, there shouldn't be any change with it on or off of the terminal.
Ken
