Old 04-07-2004, 10:49 PM
Keithc8 Keithc8 is offline
Default 427 side oiler for sale
We have some parts that were purchased or traded in on engines that we are going to build a complete 454 C.I. side oiler with.
This will include a 68 427 side oiler block that has never been exploded but had cracked in the deck in a couple of places as these 427 were known to do. These areas have been fixed by sleeving the block and giving a good sealing service at the deck. All machine work performed in house. Original 428 CJ crankshaft with reconditioned 428CJ rods, Aries pistons with plasma moly rings. Flat tappet camshaft with lifters, Comp Cams/ Dove roller rocker arm system, Edelbrock Stage 2 heads complete, Ford nice Police Interceptor intake. Stock front cover, damper sleeve, new replacement damper, Canton T-style oil pan, Ford Racing Cobra valve covers, Mallory dual point distributor and Ford Racing wires. We will also include Demond carburetor and dyno test and tune engine.
All the parts are new except the block, crank, rods, front cover, damper sleeve and intake. This will make someone a real nice engine for there Cobra at a great price. this engine is apart and waiting to be assembled and dyno tested.
This complete engine can be had for 10,000.00 of the dyno. I will gaurantee all parts to be as described and engine to produce over 500HP and more than likely depending on camshaft more like 550HP on pump gas. Thanks Keith Craft
Keith C
