Old 04-08-2004, 05:45 AM
slithering slithering is offline
Cobra Make, Engine: Midstates, Genesis 427 S/O
Mike,
If you still have a problem, Pull your positive off the battery post. Pull your fuses one at a time and put an ohm meter across the two points of the fuse receptacle. You should not get a reading. If you do, determine the fuse and wire color and find it's next connection point. If it splits, do the same test again until you complete the circuit. If you can't find it, send me a private message and we'll hook up over the phone.
Chris-
slithering
"God saved you by His grace when you believed. And you can't take credit for this; it is a gift from God".
Ephesians 2:8
