The "pilot hole" on the Ds is too small according to ERA (assume that's the center). I was afraid it might mean using a lathe to cut the rear wheel center holes larger. Not sure why ERA makes a hub for bolt on wheels which won't fit the recommended wheels ??
On the waiting list for the ERA body (August), just making sure all the parts fit before it gets here. The motor is almost finished and the transmission has been rebuilt. Had a similar problem with the toploader (shifter won't fit and no ERA adapter available). Had to get one (an adapter) manufactured when I found that out but unfortunately it was after that fact. Don't want to buy the recommended wheels if they don't fit the rear end. May take your advice and go to the IIs if I can get the machining specs from ERA.
