Old 04-09-2004, 10:37 AM
roblenderman roblenderman is offline
Cobra Make, Engine: Still looking
Send a message via Yahoo to roblenderman
Default Fixed
Turns out we had two problems. The first was that the float was a little high so it was running rich with the weather change. The other is that it had a large rubber shaving from a hose in the needle valve. Since it would float it would run fine once I set the float level but if I juiced it the fuel flow would cause it to get stuck in the needle value. Sometimes it would clear and the problem would disappear which seemed to happen every time I let it sit for some time. Thanks for all the help.
Rob
Rob R Lenderman
