Old 04-11-2004, 11:56 AM
Matt M FFR 1502 Matt M FFR 1502 is offline
Thumbs up FFR 1502 For Sale
Jet Hotted side pipes, roll bar, and quick jacks. Corvette Polo Green with Light Platinum Metallic Stripes painted by Streetrodpainter. SW gauges, Two Steering Wheels (wood and leather), VW turn signal stalk, chrome fire extinguisher, leather gear shift and hand brake boot with billet rings, Lokar short hand brake, Roll bar trim rings from Finishline, 17 inch PS Engineering GTs. Bridgestone RE71s.
Brakes and suspension
Wilwood brakes on all four corners, Buick Powermaster power brake unit, Wilwood Pro valve to rear, all brake lines braided, working hand brake. Brand new Ford front A arms and ball joints, FFR rear LCAs, Autoweld uppers, Power steering with Heidt's valve and all braided line.
Drivetrain
FMS aluminum high capacity radiator, 342 Central Coast Mustang Short Block (new block), (ESSB0ST342SB) Eagle I beam Rods and steel crank, JE forged pistons, Centerforce Billet Flywheel balanced to engine and performance dampener, Canton remote adaptor, Canton Pan, Summit high torque ministarter, Trick Flow 2:02 heads, 30lb injectors, adjustable fuel regulator, AN gas lines to engine, All AN oil filter lines, Crane 1.6 roller rockers, 73mm Mass air, 65mm TB, Edelbrock Polished Intake, F cam, Motorsport clutch, dash Adjustable clutch cable with Forte's quadrant, Brand new World Class T5, fully rebuild rear end (all new bearings) with 3:73 gears, more…. 7500 miles since built, 2500 on Stroker motor. absolutely reliable car.
$ 28,500 is the price. Matt Mengelkoch m.mengelkoch@comcast.net
Hat Trick, 342 CCM Stroker.
