Old 04-12-2004, 09:43 AM
rdorman's Avatar
rdorman rdorman is offline
Renegade Nuns on Wheels
That is going to be tough. We don't know the pan, line size, oil cooler size, oil filter, how the dip stick was marked etc.
This next time around I am going to figure mine out exactly but in the past I have used a similar method as petek. I to do not bother with draining the cooler.
I drain the oil, fill the new filter and spin it on, put in two gallons and check the level. If good, fire it up, shut it down, wait a couple of minutes, top it off. I think if I went and drained the whole bloody thing it takes like 10.5 quarts. But as it is seems to me I add about 9 - 9.5 to get it full with out draining the cooler.
As you can see in just two responses there is a pretty wide range of capacity! If it is full, drain it, measure how much you drained and put that much back in as a start.
Rick
OhioCobraClub.com
LondonCobraShow.com
