Old 04-12-2004, 05:52 PM
Bruce Edwards's Avatar
Bruce Edwards Bruce Edwards is offline
Cobra Make, Engine: Hunter with a 4.6 supercharged
A fireball out of the carb can be caused by a lean mix or to much advance for a cold engine. If you are not running a choke the engine will be lean at start up and take a bit before it warms up and makes good use of the fuel you are feeding it.
Another name for a air cleaner is spark arrester. Now you understand why and it did not take loosing you eyebrows!
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
