Old 04-13-2004, 04:31 AM
Mike Hausner Mike Hausner is offline
Club Cobra Member
Cobra Make, Engine: CLASSIC ROADSTERS 427 with a FORD 5.0 bored and stroked to 331cid, BRODIX alum heads, roller rockers, B303 cam.
In my opinion you can't go wrong with a CR unless, like Don said, the builder cut corners. The CR is a solid car and with the 94" wheel base it will be comfortable to drive. Solid body and frame.
If there is something the builder did that you don't like you can always change it. After all, it's a kit car! Corrections can be costly and should be reflected in the price.
Have an uninterested but knowledgeable third party check the car out.
Good luck
MH
