Old 04-14-2004, 04:13 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Smile
Absolutely,
Easy to assembly; easy to disassemble; no leaks; no problems. What more could you ask for?
If you want to spend your entire life chasing down leaks, (and overtightening the fittings to stop the leak--then breaking the fitting) then I guess you could keep using the NPT stuff.
Although, Loctite does wonders in solving the leaking problem. You still have the assembly and disassembly problem though.
David
