Old 04-16-2004, 08:24 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
I have fought similar demons with my MSD Dist and finally I had my cCobra at Keith Crafts shop in Texas a couple of weekends ago. They found that the pickup was actually set by the factory with too much of a gap. Rob the tech removed my dist and loosened the two bolts that hold the pickup in place and moved it over closer to the rotor. Re-installed my dist and whalla Engine starts first time all the time, even when it is hot . I also replaced everything electrical under the hood just to find out that the coil, Dist cap, ignition box solved my problem.
Lessons learned sure get expensive.
Clois
"Let's roll"
"Be part of Something Good
