Old 04-17-2004, 04:43 AM
Ken Greene Ken Greene is offline
Cobra Make, Engine: in the search, engine 351 Windsor
Send a message via ICQ to Ken Greene
to check for proper tire pressure take some chaulk and make a couple big stripes across the width ofthe tread then take the car for a short run thnen come back and check the chaulk. if its rubbed off on the edges that means not enough pressure (prolly not the case) if its rubbed off in the center with it still showing on the edges its to much pressure (most likely the case). Then adjust the pressure acordingly until the chaulk rubs off evenly accross the tire. make sure to reapply the chaulkf before each run and make sure to make both left and right turns.
will have a cobra .... someday
