Old 04-20-2004, 06:40 PM
mr0077 mr0077 is offline
Cobra Make, Engine: ERA 427 SO
Aww, man, I thought this was gonna be some kinky discussion...I used to date a "low load miss"...
Seriously, if it misses at a steady light-throttle acceleration, I would doubt it is the accelerator pump, as the throttle probably isn't moving, after the pedal is pushed down. That makes me think too much advance or too lean (but not on primary jets unless you did something to the carb)...had both happen. disconnect the vacuum pot on the distributor if it has one, see if the miss goes away. If not, maybe a vacuum leak on the #7 runner?Let us know what you find.
Ken
