Old 04-21-2004, 07:38 PM
Jim Holden's Avatar
Jim Holden Jim Holden is offline
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
Default Small block motor mounts
Bob:
Thanks for engineering the small block motor mount modification for my FIA. I installed them this past weekend and they appear to limit the motion of the motor just enought to prevent the right front Weber horn from wacking the hood.
I know you took pictures of the mounts before you sent them out. Why not post them in case anyone else has a similar clearance problem? Simple enough solution once you see them!
Jim
PS: And, once again thanks for engineering a "retro" fix for a problem (putting a small block Windsor w/Gurney Weslake Heads w/Webers in) that you might not have envisioned when you were engineering the original engine/motor mount configuration... as usual you go the extra mile(s).
