Old 04-23-2004, 12:03 PM
FattyBri FattyBri is offline
Cobra Make, Engine: FFR#5015, 351 w/ carb
Default 1995 351 waterpump help
I have a 1995 351 that has a stock replacement waterpump on it (rotates clockwise). I would like to clean up the front of the engine so i have a short triangle belt setup running the alt, wp and crank. Ive seen some guys switch to a counterclockise rotation waterpump and mount the alternator on the passenger side. I would like to do this, but cant get a straight answer on what will work on my 1995 351. Some have told me the front cover on my motor is interchangable with a 5.0.
If this is the case its an easy fix since there is a guy who makes a kit that has the waterpump and alternator brackets.
So, will the brackets, front cover from a 5.0 work on my engine? Or does anyone know if someone makes a counterclockwise rotating waterpump for a 1995 351?
Brian
FFR#5015 build in progress
351 w/Vic Jr. heads, Vic Jr. intake, Holley 700 DP, roller cam, tremmec, planned viper grey w/black stripes
